Update 2023-08-19: Now the "LED settings" page contains the "LED fade timeout" setting, so you don't have to use smart macros to use it.
Some of you want your UHK to automatically turn off its LEDs after some idle time, which can be configured by setting the leds.fadeTimeout smart macro variable in the $onInit macro as follows.
You can learn more about smart macros.
We realize that this setting is not as accessible as it should be, and we'll make it easier to adjust it in later Agent versions.
2 Responses
Can i use macros as part of other commands?
like write a few macros and then use those macros in another macro?
Like $onInit executes macro1, macro2, macro3?
Sure thing. See the
callextended macro command.
