Improved EMC test results and incoming parts
Hello, and welcome to this month’s UHK update!
TL;DR: Our most recent EMC test results are much better than the previous results, but they’re still not good enough. We’re working hard on our new prototype to pass the tests, but this delays the project by about a month. Lots of progress is happening on other fronts, too. Please read on!
Parts are flowing in
The UHK contains loads of components, and some critical ones are flowing in one by one. These are the most recent parts:
100 ANSI left, 100 ISO left, and 100 right plates have been manufactured so far. These plates will be used for the first production run. Of those plates, we have 20 of each in hand to check their quality and accuracy.
These 2 plates were surface treated with Nickel and Zinc.
There are also loads of smaller components that arrived lately:
4,000 magnet counterparts laser-cut
A couple magnet counterparts after grinding
140,000 screws
2,100 FFC cables
We’ve already ordered the switches, keycaps, keycap stabilizers, and displays which are expected to arrive soon.
The manufacturing of the guides and magnet counterparts is in progress. These are multi-step manufacturing processes, and they’re well underway.
The state of the molds
Currently, the molds are being tweaked, and the tweaks are mostly cosmetic by nature. All things considered, they’re already in very good shape.
András showed the current case samples to one of his friends recently, who works for a contractor of a premium car manufacturer, and his friend was genuinely impressed by the quality of the case, so we’re already doing pretty well.
Apart from the cosmetic fixes, we also plan to add one or two snap fits to make the case more rigid when the palm rest is attached to it. These modifications won’t affect our schedule.
EMC testing, 2nd round
Here we go again. Since our last update, we’ve created new prototypes to be tested in the EMC lab.
These are actually two right keyboard halves. The left keyboard half hasn’t been redesigned because, according to our tests, the USB is the major culprit when it comes to EMC issues, which are located on the right half.
We were told that a 4-layer PCB should perform better when it comes to emissions than a 2-layer one, so I decided that we should create both a 2-layer and a 4-layer PCB and see how they stack up.
The naked eye can hardly tell the 2-layer and the 4-layer PCBs apart, so I put an “L4” identifier right after the PCB identifier text for the 4-layer PCB. Now it’s easy to tell.
Even though my hopes were high that we’d pass the tests with the new boards, I prepared for the worst and was looking for expert help. That’s how I found Endre Köcze.
Endre has a lot of experience behind him as an electronics engineer, and he’s a pleasure to work with. He has taken a thorough look at the UHK design, and we went to the EMC test together.
The test results started off as quite a surprise. First, we measured only the laptop as a reference point, and according to the measurements, it didn’t pass! Go figure.
Previously, we used Robi’s laptop, which passed the test with flying colors. This, however, was Anna’s, my wife’s laptop. Admittedly, this laptop is not as fancy as Robi’s laptop, but a reputable manufacturer makes it, and it should also pass the test.
The first takeaway is that we’ll bring as many laptops as we can next time, pick the least heavily emitting one, and use it in further measurements.
Next, we put the laptop under the measurement table, and then its measured emission got just below the red line. But when we added a shielded USB cable, even with the ferrite on the host end, it went just above the limit. This is clearly not ideal, but this is the best we could do on the spot. The measurements are still useful, and we’ll use a better laptop next time.
In this setup, the UHK was on the table, which is the center of measurement towards which the antenna points. Being under the table, the laptop didn’t affect the measurements so much. Next time, we’ll probably use a 5-meter-long USB cable and put the laptop as far as possible.
Around the end of the measurement, the OS shut down because the battery was so low. We could still use the laptop without the OS running, but both the low battery state and the fact that no OS was running might have affected the last four measurements. The lesson here is obvious: Power the laptop from a damn charger! And on that note, we’ll probably put the charger as far from the center of the measurement as possible, too, and use an extension cord to power it.
As for the actual UHK measurements, the results are very promising. The measurements of the 2-layer PCB were no more than 4 dB above the limit and no more than 7 dB above the limit with the 4-layer PCB. This is very promising compared to the first round of measurements for which even 16 and 18 dB above-the-limit values were measured.
Endre has a concrete plan regarding the redesign of the PCBs. He’d like to add a common mode choke and ferrite beads at strategic places, and István is ready to redesign the boards accordingly.
In addition to the changes mentioned above, I plan to implement a number of firmware test features so that we’ll be able to narrow down the cause of various spikes. I think of features like disabling I2C / USB / backlighting and adjusting the clock speed of the MCU with dedicated keys on the keyboard.
I think that with all the above test procedures, test modes, and redesigns in place, we shall defeat the EMC issues with the next prototype, which should be ready in a month.
Due to the EMC hurdles, we must delay delivery by a month. This is frustrating but very much necessary to make the UHK happen. We’re working as hard as we can to hit it soon.
In our true style, we’ll be keeping you up-to-date in our weekly social media updates and monthly newsletters. Thank you for tuning in, and talk to you on 2017-04-13.
30 Responses
  1. Bummed that the keyboard will be delayed by another month. But, it's good that you guys make progress.
    1. Thanks, Nenad! We're pushing it hard to pass the next test.
  2. It really is eye-opening to see the process to make a quality product. Even more eye-opening is when reputable manufacturers cut corners to save a dollar when most of us would rather have products that work well and perform as needed. Can't wait to put this keyboard through it's paces!
    1. We can't wait to ship it to you! And thanks for your support!
  3. It is nice to see the progress. And it also shows that hardware is a pain in the back. Hopefully you will pass the next test, so you can design the final board.
    But you can already test assembling the complete UHK and tweak the assembly process (get the right tools, like torque wrenches for torquing the screws with the right torque, create fixtures etc), so when the final PCB arrives you don't have any setbacks.
    As always, keep up the good work.
    1. Great points, EdbO!
      We're already preparing for mass production. We've already made some of the tooling that will be used for mass assembly. For example, there is a tool for machining the guides, and a couple others for mechanical / electrical assembly that are in the works. András has also looked into the right torque wrences and screw dispensers, and we'll purchase them soon. Package design is also in progress.
      As a rule of thumb, we're trying to parallelize everything that's possible.
      As always, thank you for the encouraging words!
  4. Great progress team! I personally enjoyed the EMC story and the challenges of getting the right measurements, the interferences with the laptop it's a great example of the second order unknowns that we face as engineers. I have a question, do we have a decision on the rest palms yet? You presented a couple of designs a couple of months ago but they were still tentative.
    1. Thanks for the encouraging words, Pablo! Yes, we have further iterated on the palm rest in the meantime to make it stronger and more ergonomic. We're excited to unveil the final design in our next update.
    1. We're doing very well regarding our budget. R&D cost more than anticipated, but sales is also stronger than expected. We'll not only be able to pay for the first batch and tooling, but chances are we'll be able to finance the second batch, too.
    1. Sure thing, although it might take some time for us to spin up a second batch after the first, so the UHK may be out of stock temporarily.
  5. Keep on rocking!
    I always look forward to these updates, and it was very interestering read regarding the EMC test.
    I can not wait to get my hands on this keyboard 🙂
  6. Really really sad about the additional delayed month 🙁 I've kept up with using a really shitty keyboard while waiting for this one. I do realize now that I probably should have just bought another keyboard than this instead - and I ordered 2 🙁 What is the actual delivery date set to now?
    I'm glad about the honesty and information that you guys provide though - really appriciated.
    1. Hi Simon, We're really sorry about the delay, and we're doing everything we can to make the UHK happen as soon as possible. You can always check out the actual estimated delivery dates on our crowdfunding page on a per item basis. If you visit the site from mobile, you have to open the Product Choices section to see these details. Lastly, thank you for your huge support!
  7. Thanks for your guys hard work .
    I'm form China.
    I have bought some low-quality keyboards made in my home-country.
    Last year i see your project, it's wonderful, but which amazed me most is the Modules.
    I'm a programmer, these modules while help me for reducing my hand movement.
    Is there any detail information about the modules.
    Thank you for your reply.
    1. Hi Tiu Shen, and thank you for your excitement!
      We've blogged about the modules in a previous blog post which you're welcome to read. We have finalized the components that go into the modules but their mechanical design is not fully finalized yet. We plan to add 2 buttons for the trackball and possibly also to the trackpoint module. The exact shape of the modules will closely resemble the rendered pictures that you can see on our site, but might differ a bit. Right now, we're very busy with the UHK and palm rest, but from time to time we spend time on the modules, too. The modules will be the priority as soon as we deliver the UHK and palm rest.
      Should you have any further questions, feel free to ask me!
      1. thank you!!!
        I'm a programmer, these modules while(will) help me for reducing my hand movement.
        Oops!!! sorry for that misspelling
  8. Ohboyanothermonth
    IneedUHKnow!Spacebaronmycurrentkeyboardisbroken=D
    Iwillwait,keepitupguys!
    1. We better hurry, because life must be hard for you without a space bar! 🙂
      Jokes aside, thank you for your support! We're working on it.
  9. May I ask when you plan to start shipping keyboards?
    And also I'd like to say thanks for your hard work!
    1. Hi Ruslan, You can always check out the estimated delivery dates on a per item basis on our Crowd Supply campaign page. If you're on mobile you have to open the Product Choices section to see it. Thank you for your patience!
  10. I wish you luck and hope you can deliver what you promised to your backers, but its too much delay for me.. month after months and it doesnt look to me like it is final delay, you will need to test it, maybe fix some problems...and who knows when you will be able to produce second batch for us who didnt preordered, and with modules that are not finished.. I think its realistically end of 2017 🙁
    I decided to buy Matias ErgoPro which is very similar and with exception of being able to have touchpad in between palms satisfies all my requierements. I keep it here for anyone who also needs such keyboard sooner than you are able to deliver: http://matias.ca/ergopro/pc/
    Best luck, hoping to see your keyboard one day.
    1. Hi Urza,
      I'm sorry for the delays, and I can understand your situation.
      The Ergo Pro is a solid keyboard which will serve you well. I have to note though that not only it doesn't support modules, but it's not reconfigurable/programmable in any ways, and it doesn't support mouse control with keys. It also occupies significantly larger desk space.
      We're waiting you back! Have a nice weekend!
  11. Hello, i have just discovered this awesome piece of hardware and i can't wait to get it myself.
    It is really nice to see how much love you are putting into it 🙂
    I just have one problem, i don't have a credit card, because some banks in germany don't give them out for free and you have next to no use for it locally. Is it possible to pay via paypal or bank transfer?
    1. Hi Wolke,
      First up, thanks for the nice words and your interest about the UHK! 🙂
      PayPal payment is possible, it's just not publicly displayed on Crowd Supply yet. Would you please shoot an email to orders at crowdsupply dot com? They will arrange PayPal payment.
      Thanks for considering to support us, and have a nice day!
  12. Glad things are moving forward at least.
    For testing, can you RF shield the laptop to minimize its effect on the measurements? Perhaps an open box made of [0] or something similar to set the laptop in and snake the cable around? Also, if you try that route, do you know if the RF shielding on the room is reflective or absorbent?
      1. Thanks for the idea, but we don't believe that shielding the laptop is necessary. Using a better laptop far from the measurement point should work well. Also thanks for the link!
