Want to replace the steel guides of your UHK? Let us show you how!
  1. Split your UHK.
  2. Remove the keycaps which cover the 16 screws that hold the 8 steel guides.
  3. Unscrew the 16 screws with a PH0 screwdriver.
  4. Replace the 8 steel guides. (The threaded side must face upwards.)
  5. When screwing the screws of the new guides, make sure to screw properly! Don’t tighten the screws yet, so that the guides can adjust.
  6. Merge your UHK and tighten the outer 8 screws. Make sure not to overtighten the screws. A gentle force should be sufficient.
  7. Merge and split your UHK several times, so that the guides adjust to each other.
  8. Tighten the remaining 8 inner screws of the guides.
  9. Put back the keycaps.
You’re done!
