The LED display receives commands
We're happy to report that the PCA9634 IC that controls the columns of our LED display is now working as expected. This was a tricky case to solve so let us share the journey of finding the solution.
When starting to debug the problem it was rather strange that the Bus Pirate almost exclusively showed START and STOP bits but almost no actual payload. This shouldn't have happened because the I2C bus was clocked at 400kHz and the Bus Pirate should be able to decode 400kHz I2C communication because this very frequency can be selected from its menu. I still don't know what's wrong with my Bus Pirate but I ordered a new, more modern one which is on its way. Looking for alternative ways to track down the issue I broken out SDA and SCL, added a status LED to the board and reached for my Open Bench Logic Sniffer.
[fusion_builder_container hundred_percent="yes" overflow="visible"][fusion_builder_row][fusion_builder_column type="1_1" background_position="left top" background_color="" border_size="" border_color="" border_style="solid" spacing="yes" background_image="" background_repeat="no-repeat" padding="" margin_top="0px" margin_bottom="0px" class="" id="" animation_type="" animation_speed="0.3" animation_direction="left" hide_on_mobile="no" center_content="no" min_height="none"]
Sniffing the I2C communication of the left keyboard half with the Open Bench Logic Sniffer
The signals that were analyzed by the sniffer were a mix and match. Sometimes the analyzed I2C communication made sense but other times it was riddled with protocol errors. Also, the strange thing was that I2C often hanged for some reason at which point I reached to the AVR freaks to help me. They suggested that I should not use I2C from an interrupt handler which I clearly shouldn't but this code has worked on an Arduino before so I knew this wasn't the core reason. It was time to switch to an Arduino to better able to debug the problem.
[/fusion_builder_column][fusion_builder_column type="1_1" background_position="left top" background_color="" border_size="" border_color="" border_style="solid" spacing="yes" background_image="" background_repeat="no-repeat" padding="" margin_top="0px" margin_bottom="0px" class="" id="" animation_type="" animation_speed="0.3" animation_direction="left" hide_on_mobile="no" center_content="no" min_height="none"]
Using an Arduino Uno to further diagnose the problem
Initially, I haven't had any 4.7K PTH resistors laying around for pulling up SDA and SCL but had some SMD ones so I made DIY PTH resistors by soldering wires to pads of 0805 SMD resistors. The sniffed signals were still full of protocol errors. I eventually managed to get PTH resistors which probably made my circuit more reliable but most importantly I realized that the 1Mhz sampling frequency that I used with the logic sniffer was barely sufficient to sniff the 400kHz I2C resulting in frequent decoding errors.
Documentation mentioned that the sampling frequency should be at least 10x larger than the frequency of the bus to be sniffed. After making the proper adjustment I was finally able to consistently see communication clearly, both inside and outside of the timer interrupt handler. That was the perfect moment to grab the working firmware and go back to the left keyboard half to test things there.
Using a broken out PCA9634
This time I broke out not only SDA and SCL but VCC and GND too to interface with an external PCA9634 that was soldered onto a breakout board. Even though initially I couldn't control the LEDs that were wired to the external PCA9634 but the sniffer showed me that that an ACK was received after sending the address of the PCA9634 which was very encouraging.
After messing around with the code I finally realized that there was a critical bug in it. I shifted the bits of the auto increment flags not by 5 bits as described by the PCA9634 data sheet, but by 4 bits! This resulted in sending invalid register numbers that didn't make the IC do anything useful. After fixing this issue the LEDs started to toggle as expected and the sniffed communication looked great, too.
The sniffed I2C communication
At this point both the external, broken out PCA9634 and the internal one was wired to the MCU but only the external was working. It was apparent that this is some sort of an electrical problem. My best idea was to connect the SDA, SCL, VCC, GND and OE lines of the external PCA9634 right to the pins of the on-board PCA9634 instead using the previously installed wires. By replacing the connections one by one I should be able to figure out which connection is the bad one.
Accessing the pins of the TSSOP packaged PCA9634 was rather hard, being merely 0.65mm away from each other. My only option was to use my wiring pen to solder enamel wires right to the pins of the on-board IC. Eventually, I managed to break out the connections right at the pins of the IC.
The newly soldered enamel wires under the magnifying lamp
The soldered enamel wires under the microscope
The enamel wires up-close
Enamel wires soldered to jumper wires for breadboarding purposes
When powering up the board something unexpected happened: the on-board PCA9634 immediately started working! This was rather strange because I previously did continuity tests with my multimeter and based on those all connections were flawless. I guess there was a soldering error which I couldn't notice because when I pressed down the pin with the multimeter probe it must have connected to the pad beneath it and when I released the probe the pin must have gone back to its disconnected state in a spring-like fashion.
As a software developer these kinds of debugging scenarios really make me appreciate the relative simplicity of software. Not that software isn't a complex beast in itself but when being coupled with hardware issues like the above it can really be a little too stressful. But no problem; it's the nature of the beast and chances are it will never be any easier. At the end of the day challenges like this make the triumph even sweeter.
Wanna see some more photos? Head over to the photo album![/fusion_builder_column][/fusion_builder_row][/fusion_builder_container]
